stage 2 clutch for hdi
Im in need of a stage 2 clutch for a hdi can anyone help? my standard one is slipping bad to the point the car isnt moving
Try the sachs kit
http://www.ebay.co.uk/itm/Sachs-Clutch-K...750wt_1399
people say it's good for stage 2 but wouldn't go any further with it
[Image: mcetg0.png]
Anyone?
Is that the actual part number everyone has been raving about steve?
(09-03-2013, 04:04 PM)Pipps Wrote: The Sachs part number is 3000950026.
It is sometimes listed by Sachs as a Citroen Berlingo part, but it is fully compatible with a 306 HDi.
The kit cost me £154.87 from an online retailer. They even personally guaranteed it to take up 280lb/ft, and said they would provide a replacement if it began slipping within 12 months.
Here are the pics that I took of my before I fitted it:
Please feel free to rep me Wink
[Image: IMAG0158.jpg]
[Image: IMAG0162.jpg]
[Image: IMAG0161.jpg]
Hope this helps.
[Image: mcetg0.png]
Legend!!
Hmm tempting song as a friend has 2 c5s coming soon with intercoolers which are both mine with all parts
That Sachs clutch on there uk website is just short of £100 ATM as 30% off if that's the rite product code so looks like this could be the one then if all good
would love some more info on clutches to take stage 2.. just spoke to sachs uk and they said that they're not sure if sachs will take stage 2 for much more than a few thousand miles..?
Sachs wont guarantee any power/torque outputs with these clutches; their just good quality oem clutches. A few folk claim sachs have guaranteed they will be good for 280lbs/ft but i doubt they would do that with an oem clutch, they couldnt even guarantee my paddle! They said it should be good for 300lbs/ft but no guarantee however i do believe this clutch can hold 280lbs/ft, for how long im not sure, which is why i went paddle
Helix do an uprated clutch for these, non paddle, its around £380 all in, when i called them they told me it was only rated to 260lbs/ft!! They do a paddle too but its quite an expensive do.
I'd definately recommend one of these kits for £100
S2 HDi >click<
154bhp
280lbs/ft
Just got a call back from them and they said the paddle should take a lot more, but couldn't give me a price? And I imagine that takes a bit of getting used to driving wise!
Its a bit pricey... £230 iirc. And that's just for the paddle plate. I bought the Sachs kit that's on this thread to use the release bearing and cover from.
Its not too bad, just a lil snatchy but its great for gear changes when driving like a loon. They don't take long to bed in either
S2 HDi >click<
154bhp
280lbs/ft
Ah okay. so you bought the above clutch (£100) and then you changed the organic plate for the paddle plate.. that straight swap? So I could use the above clutch then if it starts to slip then just get a paddle plate fitted on it?
That's right bud
S2 HDi >click<
154bhp
280lbs/ft
(19-04-2013, 09:20 PM)W1ll Wrote: Ah okay. so you bought the above clutch (£100) and then you changed the organic plate for the paddle plate.. that straight swap? So I could use the above clutch then if it starts to slip then just get a paddle plate fitted on it?
Exactly what I'm doing, mine is being fitted as I type this.
[Image: sig-3.jpg]
Ah okay! Cheers
  HDI Stage 2 Clutch jackmiller30 1 1,772 04-05-2014, 09:50 PM
Last Post: padge
  Stage 2 clutch and pressure plate mattgreene 2 1,882 04-04-2014, 05:42 PM
Last Post: mattgreene
  Stage 2 clutch Dave26 2 2,152 04-04-2013, 10:54 AM
Last Post: dan wiltshire
