Ebay Coilover Spring Swap
Right I have read the above, I'm only going to run stupid low for shows, if I remove the helper, wind it down for shows (literally park at show wind down, wind back up before leaving) and then have it wound up for road, having 90-100 drop for shows, an 60 for road. Would the main spring cope? And when wound up the spring shouldn't become mis postioned? Is that right or am I totally wrong? And will the main spring be too soft on its own?
The above did make sense when read, just alot for my brain to process haha
But will a different make of coilovers let me go lower? Or will we just have the same problem?
[Image: Foxy2.jpg]
Foxy-jim Wrote:But will a different make of coilovers let me go lower? Or will we just have the same problem?
Depends if the shocks are shorter really doesn't it............
Team Orange Engine Bay
Ye. God this is a pain!
[Image: Foxy2.jpg]
Matt yes the main spring will cope on its own and yes it will still be just as soft as it is now. the helpers are crushed solid all the time the cars weight is on its wheels so you need to stop thinking of it as a spring and more as a 4" lowering device.
Im not sure youd get -60mm without spring dislocation risk on the std spring without a helper.
Okay dum that really helps, may look into a slightly longer main, so I can run 60 during the day and 90/100 for shows Smile
One thing I dont understand and cant quite work out in my head (and is probably a stupid question) but I dont get in my head how the raceland coilies need helpers and the gaz ones dont.
BUT
If I fit a 300lb 8" spring will it lower more than a 300lb 6" spring.
ie is the cars weight evened across the whole of the suspension travel meaning it would compress the 6" spring say 2" and also the 8" spring by 2" OR would it compress each spring say 5mm per inch meaning that it would actually drop further on an 8" spring than a 6".
Also how much further will a car drop on 275lb springs compared to 300lb springs?
Dum-Dum Wrote:One thing I dont understand and cant quite work out in my head (and is probably a stupid question) but I dont get in my head how the raceland coilies need helpers and the gaz ones dont.
BUT
Oh dont get me wrong, if I wound them down any more, they would need helpers, but I wound mine down to the point of just unseating
It'd compress just the 2"
The reason the Gaz's get away without them are the dampers and top mounts are made shorter, with shorter bushings in the top for the travel, you go to something even better like Fox/Nitron/Ohlins monotubes and they're even shorter for the same amount of travel, so there's more room for the damper to travel upwards.
Means instead of that inch you're getting to the bumpstop, there might be 1.25" on a Gaz, and 1.5" on something decent...doesn't sound like a lot, but it means the springs can be a chunk softer for a better ride whilst using the same travel, which then means the springs have more travel for a given length....
Cheers Ripp, youve been most helpful in this thread. Ive learnt a massive amount. (mainlly that I should of just bought better coilovers in the first place). Ill make sure your repped if scott/phoebe install a decent rep system any time soon
Dum-Dum Wrote:Cheers Ripp, youve been most helpful in this thread. Ive learnt a massive amount. (mainlly that I should of just bought better coilovers in the first place). Ill make sure your repped if scott/phoebe install a decent rep system any time soon
Which they wont
Ye I'm just going to buy some gaz's at some point! Maybe in the summer...
[Image: Foxy2.jpg]
or in the group buy now... ninja
Dont have the money!
[Image: Foxy2.jpg]
  Coilover protection lolsteve 6 1,429 09-01-2015, 10:22 PM
Last Post: lolsteve
  gaz coilover rebuild cost lolsteve 9 2,673 04-11-2014, 08:52 AM
Last Post: lolsteve
  TA Technix coilover topmounts toyo16 2 1,297 28-05-2014, 05:23 PM
Last Post: bashbarnard
