If Carlsberg did conrod failures....
Well they dont but Matt has had a good attempt!
thats pretty spectacular for a petrol haha
I know! If you hadnt noticed, the first pic is actually looking through one side of the block and out of another equally sized hole on the other side lol
f*ck my life that's amazing!! Haha what's the valves like?
Also don't loose that rod! I want to keep that Tongue
That's pretty good!!!
[Image: ForumSignature.jpg]
Valves are all spot on except for the exhaust ones on cylinder 1
Fair, didn't do to much to the valves then Smile
Loving the look of that Conrod though haha much damage to anything else?
yeah oil pump is well and truely f*cked, sump, spray plate, the liner has a bit of damage and i hammered a small lump off the gearbox lol
Christ did it properly then Smile gearbox? Damn you, if it still okay? As that gearbox was sweet
Don't forget the oil pump chain sprocket had about as many teeth as matts last girlfriend...
Cylinder head truly f*cked then?
Black mask Service
done a cracking job of that matt. give your self a pat on the back
Get all the bits of rod set in a block of resin as a trophy.
(06-04-2013, 10:26 PM)Matt Wrote: Christ did it properly then Smile gearbox? Damn you, if it still okay? As that gearbox was sweet
Haha yeah box is fine. You do need to get the top engine mount welded up though. Yours has cracked Sad
holy kak...well done matt!
(06-04-2013, 10:46 PM)samass Wrote: Don't forget the oil pump chain sprocket had about as many adult teeth as matts last girlfriend...
EFA Wink
Damn it Sad
Sam get the welder out Wink
Would you like me to clean and polish and wax you car as well for you sir?
Yes please that would be very much appreciated Tongue
In seriousness is the engine mount something you could sort?
Yeah I probably could, it won't be to the same level as what Davey boy could do, but it should hold
As long as it hold I don't care what it looks like haha that's what Hammerite is for Wink
unbelievable how much damage there is!
conrod failures, so last year :p
  another conrod fail CJ_Derv 22 10,414 22-05-2013, 06:12 AM
Last Post: CJ_Derv
  now a member or team shitting conrod! :( Chris_90 76 55,556 08-05-2013, 10:56 AM
Last Post: Arron
