Radiator options for rallye
What options are there for a radiator for my rallye? Basically I have throttle bodies with the longer satchel inlet so am thinking to get a shorter radiator to allow a more direct flow to the bodies so is there any options that have been done and any idea to parts involved
Iirc the 205 gti rad is normally used as is shorter and slightly wider
Anything not OEM sized would probably be a custom-fab jobbie tbh man.
If youre looking for a good oem replacement then Nissens are definitely the ones I'd go for...
I've got a nissens in it at the min I just want something shorter for airflow to the bodies
