Youtube rpm reader bosch pump
Would this work to set the max fuel screw timing rpm correct?
Half the crank speed? like idle normal 850 half 425? i kind off like this idea and i have the same rpm reader Smile
[Image: 62941977.jpg]
In that video he has 2 markers on the sprocket, so it's already corrected. So the figure you see is the relative engine speed.
With the cam covers on, you wouldn't be able to see the sprocket....
[Image: Image423_zps1ac08bc4-1_zps15c76431.jpg]
Regardless, good find on the video to show what happens in a pump under revs, rep for that
(07-04-2013, 01:24 PM)cwspellowe Wrote: Regardless, good find on the video to show what happens in a pump under revs, rep for that
It is, it shows how the gov works and gov mods are needed! Big Grin
hehe thanks yes i know the hub cap needs to go off but other than that i found it very funny to watch Big Grin
8k rpm!! Doubt Darrens seen that yet!
(08-04-2013, 10:05 PM)Tom Wrote: 8k rpm!! Doubt Darrens seen that yet!
8k = 4k?
The pump pulley looks to have two timing marks on it, so would directly relate to crank speed
Oh right.
  Slack in bosch pump? dt_ 14 12,159 21-10-2020, 03:41 AM
Last Post: dt_
  Bosch pump help for newbie PugRy 2 4,563 05-01-2020, 09:09 PM
Last Post: jamie182
  Bosch pump fuel screw broken Forby 0 3,161 12-03-2019, 06:47 PM
Last Post: Forby
