Rippthrough DT Upper strut brace only 1 ever!
Have for sale my rippthrough upper strut brace for Dt's with a xantia manifold. this is the only one in the uk and has been made to fit phase 1 bonnets but will fit other phases may also fit with the standard inlet adaptors and possibly hdis. works just as youd expect it to. This hasnt been painted so has surface rust on it now.
£65 posted
[Image: DSCN0970.jpg]
www.prestige-auto-care.co.uk
Bring it to mine at weekend if you come
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
And charge him £35 for delivery.
You wanting it Kyle?
Ye tempted as I'd have been getting one made up anyway. Just Wana check it fits ok on a phase 1/2 cross
Blaze 1.6 Dead
Is this sold?
Bump!
Bump the only one ever made!
Bump offers!
Taking up room won fit the Berlingo!
did you notice a big difference fitting this? Like big difference over a OMP for example?
Couldn't really compare it toward an omp but it certainly compliments a lower brace. I could certainly feel a difference even with dodgy p bushes at the time. The fact that its ties the bulk head in gives it rigidity some will say its in effective as its not a straight bar linking the struts. But if this was possible it would have been done. It's certainly better tiring to the bulk head rather than bending it into thin air
How does it tie to the bulk head? From what i can see in the pic, you have tapped a hole and used a self tapper?
Just trying to look at it wondering if it will fit a GTi....
Just a flat head bolt and nut with a small hole into the bulk lip where the bonnet seal is but couldn't be sure about it fitting a 6
Nah looking at the photos, i dont think it will. The bar will foul the ECU Sad
Up again
(29-05-2013, 09:23 PM)Niall Wrote: Nah looking at the photos, i dont think it will. The bar will foul the ECU Sad
Unless you do a little fettling and drop the ECU box a little lower where it mounts to the tray...Angel
  FOR SALE: Phase 1 DTurbo Sparco Strut Brace Eeyore 6 4,744 07-09-2016, 05:44 PM
Last Post: bashbarnard
  OMP Strut Brace RetroPug 5 3,814 13-12-2015, 11:36 AM
Last Post: RetroPug
  Strut brace (OMP?) silverzx 4 3,875 07-10-2015, 12:58 PM
Last Post: silverzx
