Manifold heat wrap
I was thinking of just using a heat deflector plate
this has made up my mind...........
Not sure if its a re-post..... appologies if it is
http://www.guy-croft.com/viewtopic.php?f...hilit=wrap
Youre stock manifold wont like the heatwrap mate... will rust and eat away your manifold
(04-04-2013, 02:36 PM)306GT30 Wrote: Youre stock manifold wont like the heatwrap mate... will rust and eat away your manifold
Putting a gti manifold on and those were my worries!!!!
decided instead to fab up some deflector plates and get a cold air feed to keep things a little cooler,(I hate bonnet raisers with a passion) failing all that I could heat wrap
the coolant pipes if they run really close....
Don't wrap a cast manifold!
Ignore! Didn't read about the gti mani
[Image: SDC10442-1.jpg]
Wow they hate wrap haha
Not read the thread but - there's little point in wrap IMHO unless you're really suffering from underbonnet temperatures, you will not see any discernible performance increase from it, however you are much more likely to crack the manifold etc... There's no real need for it on a stock engine for certain.
(06-04-2013, 09:32 AM)Ruan Wrote: Not read the thread but - there's little point in wrap IMHO unless you're really suffering from underbonnet temperatures, you will not see any discernible performance increase from it, however you are much more likely to crack the manifold etc... There's no real need for it on a stock engine for certain.
No, the reason I was thinking of wrapping was simply to stop
the manifold from melting things.....
its not a stock motor, but power gains were never part of the idea.......
  Heat Wrap Q's Grant 30 16,101 25-06-2013, 09:46 AM
Last Post: Grant
