lowering problem
lowering problem
hi guys i just lowered my 306 estate 55mm at the front and lowered the rear but i had to raise the rear up 40mm as it sat far too low but with it raised 40mm its still the same ride height i have shortened dampers on the rear and had to jack the arm up a good bit to get the bolt into the shock could the shortened dampers be the problem
also do i have to cut the bump stops on the front with shortened shocks
anybody ??????
gotta be the shocks if you raised it back to OE height and it hasnt moved??
as for the bump stop on the front you only need to cut then down if you keep bottoming them out.
how did you lower the rear beam??
hi thanks for the replys i was thinking it was dampers so am going to buy original dampers and see from there
i lowered the rear beam by taking the torsion bars out and adjusting the arm/hub to the height i wanted i didnt do the notch method
just drop the dampers off and see if it resets itself...like a 5min job...two bolts...done.
if the beam stays where it is...cant be the dampers!
done that just stays where it is what else could it be its a fully recon'd axle
does the arb go in last once the torsions bars are in do the shocks get fitted then the arb bolted back in
it wont be the ARB holding it down.
you couldnt of adjusted the torsion bars correctly
this.
cant be a anything else
strange ave done it twice now will try again at the weekend could anybody tell me the height from the hub to the arch
  rear lowering problem baz306 12 5,201 01-05-2013, 05:27 PM
Last Post: baz306
