My bosch pump has not got this bit
As in the title I swapped my pump from a Lucas to a bosch from a 405
And my pump has not got this bit it's just blanked of just wondering what this bit is this is the pump in jimbobs dturbo
(27-03-2013, 09:59 PM)mikey b Wrote: As in the title I swapped my pump from a Lucas to a bosch from a 405
My pump is like this
Attached Files Thumbnail(s)
it's the static advance mechanism i believe it's called . .Smile
that pictured one appears to be ecu controlled at a guess . .or maybe not lol
Cold start advance solenoid - seems to be on older bosch pumps, I'm surprised the 405 one doesn't have it tbh. All it does it advance the timing a little to make cold starts a bit easier
Nothing to worry about.
Its for the load dependant timing. Makes no odds tbh, the are both exactly the same performance, but one with the blank off causes slightly noisier cruising speeds because it maintains rpm/advance curve where as the one with the pipe backs off the advance depending on how far your foot is mashed.
(28-03-2013, 06:14 PM)Dave Wrote: Its for the load dependant timing. Makes no odds tbh, the are both exactly the same performance, but one with the blank off causes slightly noisier cruising speeds because it maintains rpm/advance curve where as the one with the pipe backs off the advance depending on how far your foot is mashed.
Ah that's cool was just wondering we just had both bonnets open and thort what the hell is that bit lol
  Slack in bosch pump? dt_ 14 3,467 21-10-2020, 03:41 AM
Last Post: dt_
  Bosch pump help for newbie PugRy 2 1,996 05-01-2020, 09:09 PM
Last Post: jamie182
  Bosch pump fuel screw broken Forby 0 1,492 12-03-2019, 06:47 PM
Last Post: Forby
