another leaky sunroof
I gave the 205 a quick pressure wash after being undercover ever since i owned it and as i feared, the sunroof doesnt keep water out.
it's one of those flip up ones so im pretty sure the seal is gone, i dont think these have drain tubes.
Does anyone know how to fix this?
1. take the glass out altogether and clean it spotless with soft cloths/kitchen roll
2. wipe all the crap off the roof seal then spray it with silicone spray.
3. refit and try again----DO NOT spray straight at the sides of the glass as a pressure washer will lift the seal from the glass and it will pour in !!
4. leak test with a hose pipe only, you are trying to simulate rain---not just trying to force seal to give way.
4.
Great thanks, i'll give it a go and report back.
I sealed the last one with mastic but i want to retain use of the sunroof this time round
I did as the above and it doesnt leak as much... it waits till I go round a bend and then the flood gates open
Looks like im going to be sealing this shut forever
  Sunroof adjustment Betty 0 1,213 31-05-2018, 11:09 PM
Last Post: Betty
  Sunroof repair ADV_93 0 803 19-02-2014, 07:57 PM
Last Post: ADV_93
  How to fix leaky rear windows and boot seal RetroPug 5 1,835 16-02-2014, 06:07 PM
Last Post: Connor
