bonnet badge (simples question)
The bonnet badge needs resprayin and a silly question but do i have to unbolt it or does it simply just unclip?
2x 10mm bolts when you open the bonnet then pulls out
thought so haha as tryed just unclipping it to be lazy but thought it was gonna snap off, so thought ill ask 1st
just the bolts behind the badge. Dont try and peel the lion and the surround off. ive done it a few times and just ruined it D:
(18-03-2013, 04:44 PM)SRowell Wrote: just the bolts behind the badge. Dont try and peel the lion and the surround off. ive done it a few times and just ruined it D:
That's because you've done it wrong mate, they're easy to remove and if done right they'll go back on again good as new Wink
quite possibly! How are you taking them apart? I drilled out the sprews on the back of the badge D:
Drilled? Christ I just popped my off using a flat blade and patients
I just buzz the fixings lightly with a drill bit to break the bond, the tips of the fixings are only melted slightly to hold the badge on. Takes seconds to get the badge off using this method and no damage...........ever Wink
^^thats how I did mine
hmmm maybe mine was particularly well stuck D: I drilled all the sprews, used a flat blade and ended up bending the outer surround and the lions arm snapped off D:
I pushed mine out by the "sprews" with a thin screwdriver
^ this.....if you try prising it from the front you run the risk of the lion's tail snapping off or one of it's 'arms' (although I've never seen a lion with arms lol)
I'm keeping quiet about the chrome edging trim and how I remove it, don't want to give too much away Wink
(20-03-2013, 04:22 AM)gareth7 Wrote: ^ this.....if you try prising it from the front you run the risk of the lion's tail snapping off or one of it's 'arms' (although I've never seen a lion with arms lol)
Give too much away? It's not exactly a specialist money making skill. lol just spill the beans!
Black mask Service
Maybe not mate but I do quite well out of custom badges......let's just say it involves a concave blade stanley knife blade.
Ah right, so i see Wink i'll let you off fella...
Black mask Service
  Bonnet Badge Modification cateraxe 0 1,910 21-10-2016, 08:16 PM
Last Post: cateraxe
  bonnet badge connorp 2 2,400 23-06-2015, 06:35 PM
Last Post: connorp
  Bonnet Badge LewisG 8 5,544 08-12-2014, 10:36 PM
Last Post: Josh1994
