HELP PLEASE!!!!
HELP PLEASE!!!!
Just had my car on the scanner after giving it some down back lanes these codes came up and went into limp mode wouldn't go above 2.5k , my scanner only reads the cose and doesn't tell u the promlem,
Just need to know how to sort it out or where to start
P0115 (I think this 1 is a temp sensor but which 1) don't hdi's have 3/4
P0320
http://lmgtfy.com/?q=P0320+fault+code+peugeot
I'd start with a multimeter, looks like you've got some sensor/loom issues there. P0320 is fairly common, could be the CPS or a wiring fault. Temp sensors, you're just going to have to check them, there's a document somewhere on here that shows the various signal outputs.
