front drop links
front drop links
Just wondering if anyone has any recommendations on what front drop links to get, mine have seen better days, looking on ebay and you can get a pair really cheap, but is this a false economy, as on my old mondeo it used to eat cheapo front drop links.
Can anyone recommend a decent brand that will last a while?
Many thanks Titch
Febi bilstein from gsf, not bad priced And oe quality.
Don't get the plastic ones, I had a pair on my s16 and after one spirited drive I parked up on uneven ground.
Everything cooled down and the link set in a banana shape
Ok thanks,
My car has the plastic ones on it at the moment, is it possible to replce the plastic ones with metal ones?
Its fine to replace plastic ones with metal ones. Prob be best to do both tbh if your changing from plastic to metal.
Dont get any cheap ones off ebay! I got some and with in 2 months the boots were split
Yeah if going from plastic to metal replace both.
I heard the plastic ones are better than the metal ones tbh
I can't see there being a difference between the plastic and metals ones but the way i look at it is that they were fitted with plastic ones as standard so there must be a reason for that but most cars these days are fitted with metal ones
Ok I may get some flack or this but what exactly do drop links doo ?? I've lowered my car and a mechanic m8 says to get adjustable links ?? Do I need to and what will happen if I don't ??
  Damn spinning drop links Iaitoo 24 13,427 02-02-2016, 05:51 PM
Last Post: Iaitoo
  Drop links - and now tie rods :) Iaitoo 11 4,977 16-12-2015, 06:36 PM
Last Post: Frosty
  Drop links spec mattbarker32 27 10,147 06-08-2015, 04:05 AM
Last Post: maxzy
