gti6 master cylinder swap
hi guys
i know theres a different bore between the gti6 n the standard 1.9 td master cylinder but does it brake any better or not
ive got discs front n rear (front gti6 set up)
n if there is
is there a easier way to change it without bleeding every corner
any info will be most helpful
Imo defo need to change it....
along with some decent 5.1 brake fluid and the pedal will feel epic!
...and no...need to bleed it all...but use it as a chance to put some decent fluid in it
It doesn't make the brakes any better but it does make them feel a lot better. Well worth it considering how cheap and easy to change they are.
[Image: 20120704_212316.jpg]
(04-03-2013, 10:08 PM)Ben Wrote: It doesn't make the brakes any better but it does make them feel a lot better. Well worth it considering how cheap and easy to change they are.
unless you are phase win with no ABS and they don't fit . . .Smile
Confused I fitted one to mine easily enough.
Edit : Forget that, didn't read your comment correctly!
I've got abs is it gona piss it up or is it stupidy simple to swap ??
Stupidly simple to swap. I think you just undo two brake lines, then undo two nuts and its off. Then opposite to fit new one. Think theres an O-ring remember to check thats there or re-use old one.
Think thats just you matt, went straight in mime without issue. For whay reason dpes it not fit yours????
^^^^^^ Same
Peugeot 206 GTI HDI
Volvo V50 2.0d
Volvo XC90 D5
hi I've finally got round to trying to fit my gti6 master n found the bottom union is larger than my standard 1 just wondering if I've got the right master cylinder or not
part no 21028799 on cylinder
  HDi 23.8mm Master Cylinder - Where from? Alan_M 3 3,269 07-09-2016, 02:33 PM
Last Post: Alan_M
  23mm Master Cylinder with 266mm Brakes MY95 18 11,013 16-04-2015, 01:42 PM
Last Post: MY95
  Hdi master cylinder tysonbully2k12 0 1,889 24-02-2015, 04:43 PM
Last Post: tysonbully2k12
