Rear beam repair kits
Right, I have a Hdi rear beam with slight play in os, I've put bearings in before on my dturbo, but as I only have the axle and no car details,
The question is:
Are all tubes the same size?
Is there only 1 size of inner and outer bearings?
And where do you recommend getting repair kits from?
Take the beam apart before ordering anything as it could be beyond repair, Parts can be got direct from Pug, Me or Ebay etc
Parts are all the same on 205, 306, ZX, Xsara
Will the rear beam off any of these cars fit a 306 ?
A Xsara beam will do, and the VTS is a very sought after rear beam as it has 21mm torsion bars (compared to the 20mm torsion bars on a GTi-6)
(03-03-2013, 10:19 PM)Scott Wrote: A Xsara beam will do, and the VTS is a very sought after rear beam as it has 21mm torsion bars (compared to the 20mm torsion bars on a GTi-6)
As do the later estate beams i believe.
  Rear beam ...the good and the bad Mighty306 35 31,573 23-07-2020, 10:13 PM
Last Post: Mighty306
  Rear Beam Pgtips 1 3,431 26-06-2020, 07:19 AM
  Rear beam rebuild MOK 21 15,986 18-03-2019, 03:40 PM
Last Post: MOK
