Threads: 208
60
Given 5 thank(s) in 5 post(s)
03-03-2013, 11:40 AM
(This post was last modified: 05-03-2013, 06:50 PM by puglove .)
Right got a massive issue with my bosch and cant get hold of ruan so...
My bosch wont pump fuel . when cranked over it wont pump any fuel through the injecter lines, iv taken the lines off and there is the slightest dribble from where the lines meet the pump.
Now iv taken the Stop solinoid plunger out as advised by ruan , still the tinyest dribble, so iv taken the stop solinoid out completly and when cranked over fuel comes out the solinoid housing? WTF is going on with this pump???
Threads: 476
81
Car Model/Spec: 306 Rallye
Are there any chips or bits of bacon stuck in the fuel lines?
Sorry for not being helpful...
Threads: 34
8
Given 8 thank(s) in 8 post(s)
Threads: 9
3
Car Model/Spec: XSI 16v
Given 1 thank(s) in 1 post(s)
i believe it is a standard pump
138 BHP XSI
Threads: 208
60
Its 9mm . Iv got the lines off completly and still nothing. Yet getting fuel from the solinoid housing
Threads: 34
8
Delivery valves seized? Do u get it out of the holes if you take them out?
Threads: 208
60
Sorry what? Lol . Out of what holes?
Threads: 34
8
Where the fuel lines attach to the pump, if you take the bits off where the lines bolt onto? Get me?
Threads: 226
24
Car Model/Spec: A3 TDi
Hammer.
Threads: 208
60
Took it all apart valves are all good and free. Turned it over again. Still nothing
Threads: 130
82
Car Model/Spec: 106 GO-NAD
How far did you take it all apart?
Threads: 208
60
Take what apart? The injecter valve bits? Or the pump? Iv not had the pump apart fully but thats not to say it hasnt been before i got it
Threads: 34
8
Wonder if a seal etcs gone and there's no enough pressure, or vane pumps seized.. Mine did a similar thing but the shaft inside snapped and was only squirting like a little kid..
Threads: 208
60
Just seems strange that it gets as far as the solinoid but wont go any further , this is doing my fecking head in now
Threads: 34
8
Not pumping enough by sounds.. Do you get it out of the holes delivery valves go into if u remove them?
Threads: 208
60
It wouldnt be that someone has wound the max fuel screw right out would it?
Threads: 48
5
Car Model/Spec: Peugeot 306 S16 Cossack
Given 2 thank(s) in 2 post(s)
Possibly
Peugeot 206 GTI HDI
Volvo V50 2.0d
Volvo XC90 D5
Threads: 208
60
Anyone got a pic that shows the max fuel in OE possion?
Threads: 119
5
Car Model/Spec: MG ZS180
Give it a full turn and then see if it pumps fuel, if it does, tighten up the unions and then try and start, just be ready on the clutch in 5th just in case..
Threads: 208
60
Dosnt look like its wond out
Thumbnail(s)
Threads: 151
14
Car Model/Spec: 306 D-turbo
That's still got the security seal on so fueling hasn't been touched
Team Doesn't own a 306
Threads: 119
5
I take it you have the wire attached to the solenoid? As there's no wire in that picture..
Threads: 208
60
Iv took the internals out of the solinoid so effectivly its dosnt have one atm
Threads: 151
14
You done a Lucas to conversion?
Threads: 208
60
Yeah iv taken the lucus off n put a bosch on
Threads: 151
14
You put all the pipes on in the right place? Easy mistake to make
Threads: 208
60
Well im getting fuel right up to the stop so all the fuel in is right. What could i get the wrong way to couse this?
Threads: 151
14
Ahh didn't read that bit, is it pissing out or still dribbling out?
Threads: 208
60
Got the tinest dripple from the injector line ports
Threads: 151
14
Shame I'm so far away i would come and lend a hand
You slackened the fuel banjo off at the back of the pump to see if diesel is getting in?
Have you used a Bosch bracket
