No fuel from bosch
So iv got the car to the point where it should run but getting no fuel from the injecters. Iv got what apears to be 2 solinoids . Whats going.
Pics of solinoid and wirering
The bottom is the static advance the top one is the stop solenoid.
On the stop solenoid (top) splice into the black wire and add some wire connect it to the battery and if it clicks then the solenoid is working if it dosent make a sound then its faulty and thats why it wont start
Had this problem a few weeks back.
Team Doesn't own a 306
Did you extend the red wire to the top of the solenoid as per the other thread? Looks like your still using a plug there...
Leave bottom solenoid dissconnected, find red wire in black plug if it was immobed before, if not just any wire thats live with ign, and connect to the top solenoid Smile have you tested to see if theres power on the solenoid?
Just spoken to Jamie, apparently there's no fuel from the pump at all, the solenoid clicks, fuel is primed up to the pump.
  Bosch pump fuel screw broken Forby 0 3,142 12-03-2019, 06:47 PM
Last Post: Forby
  Bosch Fuel Pump governer shaft (spline)please HELP! Dantheman1312 10 5,544 05-07-2016, 07:19 PM
Last Post: Piggy
  recommended BOSCH fuel pump for XUD7TE assembled 24 17,431 24-03-2016, 03:23 PM
Last Post: assembled
