HDi Engine Faults?
Afternoon all,
So a hdi goes into limp mode, and when hooked up to diagnostics, the following codes come up:
P0190 Fuel pressure sensor circuit
P0100 Air mass sensor circuit
Now, are these definitely only sensor faults, or potentially wiring also? Are they easy/cheap to fix?
Any help appreciated!
Almost defo in tank pump failure.
And possible Airflow meter failure.
So if it's an in-tank failure, do they still run, albeit in limp mode?
Air-flow meter; is that the maf?
(25-02-2013, 02:48 PM)Ed Doe Wrote: Air-flow meter; is that the maf?
Indeed
A lot of the time that fuel code turns out to be FPR or clogged filter or leak-off pipes or something else daftly cheap to fix, you may as well check out those options first. While you're checking the fuel filter, have a look to see if there's any glittery bits in the housing - if there are it's the LP pump eating itself.
Bring it over at the weekend and i'll have a look with pp if you like.
Didn't know you had pp poodle? I haven't bought it, but found a cheapie and was tempted.... Still am tbh!
Had it for months mate, its useful if youve got a lot of call to use it, which for some unfathomable reason I usually do lol.
(26-02-2013, 01:46 PM)Poodle Wrote: Had it for months mate, its useful if youve got a lot of call to use it, which for some unfathomable reason I usually do lol.
Mines on it's way out to me... Finally bit the bullet. I think I'll get a fair bit of use out of it tbh...
Haha such are the joys of owning a Peugeot!
Ed i would of thought you of all people would be able to put this in the correct section? Clearly all that panicking about your absolutely f*cked car has gotten on your mind?!
  faults pug306driver 3 2,855 08-04-2016, 02:55 PM
Last Post: pug306driver
  Pp2000 faults LewisG 18 11,231 21-11-2014, 11:10 AM
Last Post: pro_steve
  Scanner faults Hec1872 4 3,109 15-07-2014, 01:10 PM
Last Post: Tom85
