central locking locks and unlocks
Got a good friend with ph2 turbo diesel...
coming to stay soon to see us all but also to get a service and get things fixed
an issue she has is that when she locks the car it locks all the doors and unlocks straight away!
BUT a garage has recently, as some expense, repaired the door looms.
so...what would it be? a locking motor? or a jammed lock?
I ask as if I need a part...I want to have it ready!
thanks, Piggy
(19-02-2013, 08:24 PM)Piggy1987 Wrote: Got a good friend with ph2 turbo diesel...
thanks, Piggy
What's the loom "repair" like?
Only had this when the wires where sorting out in the worn door loom.
Sorry if this is not of much help.
duno yet...I suspect it but didnt know if anyone else had same issue but fixed it differently
anyone else?!
Mine did this, do both locks go down and go back up or just one side.
Mine turned out to be connector not plugged in properly on drivers side
S2 HDi >click<
154bhp
280lbs/ft
...5door...all locks lock and then immediately unlock
Ph2 with Ir remote control
find the locking control box black plug link wires 8-12 the box will think the doors are locked and stay locked
cheap fix or dear fix fix the door looms or lock switch's once you found the faulty bit
http://www.nickhill.co.uk/peugeot_306_ce...ng_up.html
.pdf   Fixing Peugeot 306 central locking popping up, re-opening, not staying locke.pdf (Size: 347.56 KB / Downloads: 179)
ok...do need to fix...
but repped for the pdf...thanks matey
  Central locking/deadlocking/immobiliser going beserk. pug306driver 5 6,243 29-01-2022, 09:29 PM
Last Post: pug306driver
  central locking bypass auto unlocking andyw 1 3,676 04-07-2021, 03:58 PM
Last Post: Mighty306
  Universal remote central locking carrot 1 4,200 19-02-2021, 07:58 AM
