Hi guys need a bit help have a slight blow on the cylinder head gasket [ usual symptoms ] searched the web and getting slightly confused on the type of head gasket required, will be changing timing belt and pullies at the same time as there is no record of this being done. Is it worth changing the water pump at the same time. the car is 2000 vintage
Regards
Regards
