Threads: 183
20
Given 8 thank(s) in 8 post(s)
25-09-2014, 01:16 PM
(This post was last modified: 25-09-2014, 01:18 PM by kentiiboii.)
QUICK REPLY NEEDED PLEASE!!!
Just come to fit my rippthrough lower brace, but I have a power steering pipe that runs under the engine in the way. If I give it a bit of force I can just get it on, will that be ok?
Here we go.
Threads: 183
20
Sorted it, someone had bolted the pipe wrong way round before hand.
Threads: 164
25
Car Model/Spec: Gti6
Given 4 thank(s) in 4 post(s)
Yeah that pipe was a bit low on mine and rattled on the brace until I adjusted where it sat
Threads: 183
20
Yeah once I noticed where it was wrong the brace went on fine.
Didn't think it should of been that low.
Threads: 55
17
Car Model/Spec: 406 V6
Those sometimes get bolted on too low even when they're up in the right place - there's quite a lot of slop on the bolt holes, so it's worth checking it's as far up as it'll go before fitting a brace anyway
Threads: 541
124
You still making these Phil?
Threads: 55
17
I will be when I get chance - I've got some steel bent up ready, just need to weld up some ends and chop and weld the lot together, things are a bit hectic atm, lost my nan about 6 weeks back and my grandad's in a bit of a mess, so I'm on babysitting duty/suicide watch at the minute, which is taking up most of my spare time.
Threads: 55
17
I saw it, and the other one
I've got enough for 10-12 braces but am busy with the buggy and some other work for the next week or two, I'll see if I can knock some up the weekend after next.
