Xud engine
Wanted: Xud engine
Show me what you got Smile
I have a few but your a fair way away
Team Doesn't own a 306
Joe205 is breaking a dturbo in Shrewsbury ?
might want to add a GT2056 to that wanted list too Tongue
got a couple bottom ends and a fully re con head ? but again your quite far away
I have one. Same one your Bosch pump came off Wink I may have f*cked something in the gearbox a couple days ago though so err yeah. The clutch arm was stuck while trying to remove the gearbox, pry bay + force and something has gone screwy. Looks to be near that white plastic bit on the bottom of the 'box.
EDIT: Needs a water pump though.
So there's notiong wrong with the engine? Just the gbox?
(11-02-2013, 04:52 PM)Matt Wrote: So there's nothing wrong with the engine? Just the gbox?
Yep. Only reason I broke it was because the water pump went dodgy and the cambelt started rubbing on the covers, didn't slip though. Other problems like the beam meant it wasn't worth fixing. Still in the car atm as have no means of getting it out although if you fancy doing the subframe method I'll help.
It's just the engine too, have just sold the PAS pump. Alternator is still about though and have the aux pulley and tensioner still.
Gearbox might be fixable, must be a reason they have that white plastic cover down there.
Although the wallye PAS pump might fit, both XU blocks without A/C
Sure it can be sorted. What sort of money are you looking for?
(11-02-2013, 05:14 PM)Matt Wrote: Sure it can be sorted. What sort of money are you looking for?
Tbh, make me an offer. I was expecting to just leave it in there with the shell. £50?
As I said though, will need removing from the car and I don't mind helping.
You still after an engine numty?
What have you done?
Haven't done anything, it was a ninja thing, but in two minds again haha
(20-02-2013, 09:31 PM)Matt Wrote: Haven't done anything, it was a ninja thing, but in two minds again haha
Do you really have enough money to be ninja projecting? Lol
It's a cheap ninja thing, put tbh I don't think it's gunna go ahead lol
