No central locking or interior lights only works when the ignition is on
Hi, is have a 99 Peugeot 306 estate, my central locking, interior lights, hazards lights only work with the ignition on. Also the stereo does not hold its memory and the little center console screen with time and temperature is flashing. Can anyone help me please? All fuses are in tack!
Thanks
Central locking and interior lights I would put down to a split or broken wire or 2 in your door looms most probably drivers side as I have the same problem and I have a broken drivers side loom
go in the fusebox and you will see a fuse that can be moved down or maybe up as there is one more slot, change that and your stereo will now hold it's settings . .Smile
(07-02-2013, 04:10 PM)Mattcheese31 Wrote: go in the fusebox and you will see a fuse that can be moved down or maybe up as there is one more slot, change that and your stereo will now hold it's settings . .Smile
(07-02-2013, 04:32 PM)nivag1982 Wrote: [quote='Mattcheese31' pid='212493' dateline='1360253449']
Is that the single fuse in the middle so you have a group of fuses to the left and to the right and then there is two slots one above the other in the middle, currently the samfuses is in the top hole? I will try it at 5.30 when I finish work.
I will have to check the door loom for the other problems at the weekend. Thanks
That did not work moving the fuses, my dials stopped working! Any other ideas?
you've moved the wrong one then . . Smile i'll have a look later, can't quite remember exactly where it is .
or it could be that it's wrong on the back of your stereo, take it out and look, on the power wires there may be a spare with push fittings for the live feed, swap that round
Mine is the 30 fuse box if that helps, I have tried on the back of the stereo still did not store anything. If you can find ia picture that would be a great help. Thanks
(07-02-2013, 06:00 PM)nivag1982 Wrote: That did not work moving the fuses, my dials stopped working! Any other ideas?
I have found the right fuse all sorted for the stereo it now holds its memory thanks, now to just try and sort the central locking, hazards etc out.
(08-02-2013, 09:52 AM)Mattcheese31 Wrote: you've moved the wrong one then . . Smile i'll have a look later, can't quite remember exactly where it is .
good man, glad i could help a bit . .Smile
  Central locking/deadlocking/immobiliser going beserk. pug306driver 5 5,955 29-01-2022, 09:29 PM
Last Post: pug306driver
  central locking bypass auto unlocking andyw 1 3,551 04-07-2021, 03:58 PM
Last Post: Mighty306
  Universal remote central locking carrot 1 4,060 19-02-2021, 07:58 AM
