22-01-2012, 10:27 PM
What does this sound like?
22-01-2012, 10:35 PM
Of course that's the problem... will never run right with a Lucas injector
306oc Chat Wrote:15:30: Toms306 - :Genuinely thought it was gonna explode when I was playing with Sam ![]()
22-01-2012, 10:40 PM
Connor Wrote:Of course that's the problem... will never run right with a Lucas injector Really? i thought they'd still run, just under a lower pressure? hm this makes me think...
22-01-2012, 10:41 PM
If you listen carefully.....sounds just like a golf! :o
22-01-2012, 10:42 PM
Yeah Lucas injectors "work" but won't be right
22-01-2012, 10:45 PM
Connor Wrote:Yeah Lucas injectors "work" but won't be right but would it create that sound? am i getting that sound right - air blow sounds like??
22-01-2012, 10:57 PM
It never did it with Lucas and only does it when it gets warm hopefully ill see what happens when I get a Bosch injector in there
22-01-2012, 10:58 PM
Ive got 4 lucas injector on my bosch pump. My mate did what you have done but he had 3lucas and 1bosch and it sounded same change injector too bosch job done
![]() STAGE2 XUD DEAD ATM ENGINE REBUILD GARRET T2-BOSCH PUMP-GROUNDED LDA PIN-GOV MOD-FMIC-STRAIT THRU STAINLESS EXHAUST SYSTEM COMING SOON TD04
22-01-2012, 10:59 PM
Either run bosch or lucas, both will work, but you cant mix them up...they break at different times, so timing is all over the place.....
| #DervMafia | ![]()
23-01-2012, 12:10 PM
Right cracking! Ill get it sorted! Thanks for the help guys!
![[Image: connorsig.jpg]](http://www.306oc.co.uk/forum/images/uploads/connorsig.jpg)
![[Image: mintsig.jpg]](http://i1235.photobucket.com/albums/ff436/studturbo/mintsig.jpg)
