slight idle issue (video)
Ok so commented on a post before about when the car was idling it was a little lumpy and smoked a bit I thought it would go away when warm and drove bout 10 miles to the shop today and stopped and noticed the car still does it it drives 100% it just does then when you come to an idle almost sounds like is has an aggressive cam lol.
Any ideas what could be the car is still running standard boost and fuelling.
http://m.youtube.com/watch?hl=en-GB&gl=G...MMzVSX-R6Y
When was it last serviced.
I'd actually probably put money on it being fuel filter
(03-02-2013, 03:02 PM)4WayDiablo Wrote: When was it last serviced.
Wouldn't have a clue about servicing mate got the engine out of a 405 that had been crashed before xmas I know an old guy had it and probly never serviced it changed the timing belt before put it into the engine but never serviced it think that should be the next port of call the oil is pretty thick in it also.
Have you come across this issue before?
  Slight starting issue, lumpy idle, etc Dazecoop 6 3,740 05-04-2016, 10:40 AM
Last Post: Iaitoo
  cooling pressure issue(video inside) bashbarnard 4 3,038 02-09-2015, 02:44 PM
Last Post: bashbarnard
  Slight miss fire sherman306 19 8,608 10-01-2014, 01:39 PM
Last Post: sherman306
