Threads: 110
20
Car Model/Spec: Estate, DT, GTI6 and 205
Given 30 thank(s) in 30 post(s)
As titled I'm after a S16 diaphragm for the inlet manifold. 1 for the cam belt end. Not sure if there different for each end. Maybe be interested in a pair though. Must be in working order and have the nipple to connect the pipes
Threads: 57
3
Car Model/Spec: 306 s16 406 v6 Saab 93 Ttid
Given 3 thank(s) in 3 post(s)
They are both the same, mountedon a metal plate that screws to the bottom, you can swap these over
If your careful it is possible to pride them open and re glue the membrane inside if that has split
Threads: 110
20
Bump on this.
Started driving the s16 again and 1 of the diaphragms isn't work and not holding vac so is anyone able to help me out?
Threads: 465
114
Car Model/Spec: Vauxhall
Given 98 thank(s) in 92 post(s)
mr superglue to repair the diaphram
Threads: 110
20
Might take it off and have a look/go at sorting fixing it
Threads: 110
20
Bump on this if anyone does have some spares as i have run out of spares
Threads: 26
0
Car Model/Spec: 205 Mi16 and 306 HDI
Given 0 thank(s) in 0 post(s)
Gti6 inlet problem solved
Threads: 110
20
Not giving touch away then? Lol
Is your 205 on the road?
Threads: 110
20
I managed to get a new 1 from Peugeot but was the last 1 they had
