ph2 into ph1 door looms???
Right guys. Im planning to put my ph2 door cards into my ph1. I still want to retain the ph2 window amd mirror switch. Also add the electric mirriors.
Iv stripped the door looms from my old ph2 to put into the ph1.
So is it a case of strip out the old then plug and play with the new, and add the lecy mirrors?
Any one ever done this?
I don't see why you couldn't.
In typical Peugeot fashion I would imagen There will be a few wires left over though
Most of it should work, not sure about the mirrors though. Check your door loom plug with the one on the car, if there is the same amount of wires then maybe. If not you will have to get a door loom plug from the scrappy and wire them in manually
HDi Cabby Project Click
  Door wiring looms Dturbo lad 2 2,720 03-01-2015, 12:31 PM
Last Post: Dturbo lad
  Help! Ph1 to ph2/3 switch looms. underground375 9 5,890 26-10-2013, 11:22 PM
Last Post: ConorTRG
  Door Looms - Wiring Guide anto 11 10,889 05-02-2013, 12:20 PM
Last Post: anto
