Bosch pump problem???
Guys my dtub is taking ages to start but the glow plugs are new once the engine does start it runs awful and it sounds like a misfire this is right up the revs u can't drive it steady as the engine is allways lumpy.. Checked my injectors and they're ok checked fuel going to the injectors and found no.1 not giving as much fuel as 2,3 n 4. So is it a pump problem or...??
[Image: blazejpg1.jpg]
Does it improve as it gets warm. Are you running veg or diesel. Also worth check fuel filter and glow plug relay
HDi Cabby Project Click
Nope I drove to Pompey and back (12m ish) and i changed all filters before the Coventry Xmas meet.. And glow plugs work I pulled them out and turned on the ignition they glow pretty well. And diesel
Timing may have slipped a tooth. Cambelt cover and starter motor off and lock the flywheel, cam, and pump to make sure it all lines up ok.
Will ther be marks I can go by?
  Slack in bosch pump? dt_ 14 12,049 21-10-2020, 03:41 AM
Last Post: dt_
  Bosch pump help for newbie PugRy 2 4,536 05-01-2020, 09:09 PM
Last Post: jamie182
  Bosch pump fuel screw broken Forby 0 3,148 12-03-2019, 06:47 PM
Last Post: Forby
