Gti6 brakes onto lower spec 306
Hello guys,
On my diesel LX runaround the brakes are pretty shocking (very little pedal feel etc) and I have a gti6 that I am breaking for parts.
What is involved for putting the gti6 brakes onto the LX?
I was just planning on taking the master cylinder, discs and calipers and swapping them over. Is that all I need? Any issues that I might come across?
Any help would be great, thanks Smile
Chris
1999 China GTi6 Supercharged track car
2000 Bianca LX non turbo slowness
Team: I hate Sam Rowell's stanceboard!
just as you have said iirc simply swap everything over
[Image: J5hxCcC.jpg]
Yep just swap everything over.
Something else is wrong, check for leaks/servo clearance first, in case you swap it all over and still have the same problem...
There's some shocking pads out there for those calipers too, I slapped a cheap set on mine once and they may as well have been planks of wood. Dodgy
(21-01-2013, 02:50 PM)Rippthrough Wrote: Something else is wrong, check for leaks/servo clearance first, in case you swap it all over and still have the same problem...
But that's all a 1.4 running on max 3 cylinders at any 1 time need to control that power.....
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
Whether it is or not, the brakes shouldn't be spongy with little pedal feel.
I haven't found a 306 yet that matches the pedal feel of mine even when it was back on 247mm solid discs...people just band aid another issue with bigger brakes.
  GTI180 vs GTI6 Brakes MY95 18 8,360 19-11-2015, 09:29 AM
Last Post: Anton
  Gti6 brakes connorp 10 5,392 27-05-2015, 03:55 PM
Last Post: connorp
  Benefits of gti6 brakes Nathan1305 81 47,672 03-10-2014, 04:44 PM
Last Post: mcglynn
