Threads: 115
26
Car Model/Spec: 306
Well i got the engine out of the 6 today and found this
Has anyone else had this problem and what is the best way to fix it? replace the whole mount or weld a cup in to the existing? or is she destin to be broke for parts?
Threads: 130
82
Car Model/Spec: 106 GO-NAD
its repairable, look on the '6 forum, theres a thread on there that some was doing repair cups for them, i forget the user name, but maybe Ed or someone will
Threads: 115
26
Car Model/Spec: 306
20-06-2012, 06:20 PM
(This post was last modified: 20-06-2012, 06:28 PM by spike2002.)
will have a look on there now thanks mate
sam is it daveyboy on the 6 forum that does them? im not a member on there can someone get me his contact number?
Threads: 130
82
http://www.306gti6.com/forum/showthread....631&page=1
theres one
and here's daveyboy's one
http://www.306gti6.com/forum/showthread....625&page=1
i cant pm as im not a paid member, i just registered so i can see pics. but he runs R H Davey Welding Supplies in Southampton, and a quick google comes up with this:
http://www.ihampshire.co.uk/profile/4634...R-H-Davey/
i think if you cantact him he should be able to send you the repair peice then you can get it welded in yourself, seeing as you wont be able to get from brum to southampton lol
hope that helps
Threads: 9
19
Given 3 thank(s) in 1 post(s)
My DT did this, I just made a template from card that fitted into the bottom of the mount perectly, I then cut that out of 3mm steel plate drilled the hole in the correct place and welded a nut to the back and then welded it into the bottom of the mount, job done
Threads: 138
72
Car Model/Spec: Mincebus
Dammit Samass, I was on this like a tramp on chips, just about to post Daveyboy's chassis repair thread and you've already done it!
I am however a fully paid member of the '6 forum (I got so fed up with not being able to contact members when I was looking for another '6), so I'd be more than happy to pm him for you if you want...
Astor 'X' 4 GTi6- 6 - SOLD!
Threads: 130
82
(21-06-2012, 07:16 AM)Ed Doe Wrote: Dammit Samass, I was on this like a tramp on chips, just about to post Daveyboy's chassis repair thread and you've already done it!
You snooze, you lose
Threads: 42
Car Model/Spec: 306 XRDT
(21-06-2012, 06:51 AM)mark_airey Wrote: My DT did this, I just made a template from card that fitted into the bottom of the mount perectly, I then cut that out of 3mm steel plate drilled the hole in the correct place and welded a nut to the back and then welded it into the bottom of the mount, job done
Mark is here any chance you could help me do this as it has happened to mine?
Threads: 9
19
21-06-2012, 12:00 PM
(This post was last modified: 21-06-2012, 12:01 PM by mark_airey.)
(21-06-2012, 11:48 AM)D@wson Wrote: Mark is here any chance you could help me do this as it has happened to mine?
Yeah if you remove the engine first.................... can't get my welder in otherwise!
I did it while i was swapping engines last time round sorry fella! You will have to find someone nice that would be able to do it for you!
Plus I don't like doing things like this on other peoples cars in case something goes wrong!
Threads: 115
26
Car Model/Spec: 306
Thanks for all the help lads rep yor way
Ed i have got chris to pm him my number on the 6 forum as im not a paid member
When i sin the cradle i was thinking time to break her looks like she will survive tho
Threads: 115
26
Car Model/Spec: 306
Rite looks like im going to have to make myself a cradle repair kit as daveyboy doesnt do the diy kits anymre
Threads: 42
(27-06-2012, 05:47 PM)R45_ODV Wrote: Rite looks like im going to have to make myself a cradle repair kit as daveyboy doesnt do the diy kits anymre
I wasn't sure he did, will have to make my own too.
Threads: 581
195
Any good fabricators will be able to repair/make something for that.
Threads: 115
26
Car Model/Spec: 306
I can make it and weld it in just a pita as wanted it done quick will just put me a week of so behind on fitting the engine
