Threads: 8
i have been looking at cars with launch controll kits and i love how when holding it at the optimum revs on the launch controll kit the exhaust flames nicely however i can't seen to find a sutable kit can anyone help me?
Threads: 581
195
I think there was an ad on for the Omex 600 ecu to Allow you to do that but spending over 500 on a ecu plus however much for the launch control is a bit excessive.
Threads: 8
yes i won't be spending that money for one lol thanks for the reply i would have spent the 100 that i seen the kits for but they were for single coil or double coil engine's
thanks again paul,
Threads: 581
195
Limit your throttle cable to about 4k, hold your foot on the floor at lights and dump the clutch. Simple!
Threads: 90
54
Launch control on an NA fwd petrol 306?
lol?
Threads: 289
92
Car Model/Spec: Phase 17 R26
Given 1 thank(s) in 1 post(s)
It does have pretty uncontrollable torque...
Threads: 91
83
You probably could yes... It's just whether 1AP accepts different timing or limits based on VSS...
However, for what it'd cost to have done and someone figure out, not worth it. You might as well go standalone from day one.
Other way you could do it is with a No-Lift Shift kit, it'd probably take in to account the clutch pedal position and then cut the ground to the coils when the revs go over a defined limit... It's just whether you'd end up wrecking the Coil Drivers doing that...
(16-05-2016, 10:45 AM)Toms306 Wrote: Oh I don't care about the stripped threads lol, that's easily solved by hammering the bolt in.
Threads: 90
54
But why? A stock gti6 dosnt need launch control :S
Threads: 91
83
Oh no, I wasn't saying there was any point.
There isn't any!
The only time you might want to is for chronic flames, but the GTi6 exhaust manifold is fairly thin steel and will probably crack if you do.
Threads: 179
21
Car Model/Spec: Broken Phase 2 GTi6
Given 17 thank(s) in 12 post(s)
(21-06-2012, 10:18 PM)Scott Wrote: It does have pretty uncontrollable torque...
only if they use NGK Spark plugs.
They push you back in your seat you know.
1. Fooby's Car
2. Fooby's Hire Car(s)
3. Fooby's Company Pool Car
Team Self Improvement
1. Learn to Car
Threads: 581
195
(21-06-2012, 11:23 PM)Fooby Wrote: (21-06-2012, 10:18 PM)Scott Wrote: It does have pretty uncontrollable torque...
Has to be the Bosch super 4s mate. They give you 3 more sparks per cylinder you know.........
