Threads: 71
Car Model/Spec: 205 dt
new about the problem when I got the car but not hapened for a while, runs perfectly fine apart from when I come to a stop/ no revs in neutral the revs will drop and the car dies. apparently it used to rev itself aswell, this sound like the icv?
how do you go about cleaning it anything special to look for do? or pretty self explanatory?
or anything else could be causing it?
81
What engine is it? Id unscrew it and give it a quick clean making sure you dont break it. Otherwise get one off a car in a scrappers cheap and try that before buying a new one!
Undo it from the manifold, unscrew it and douse it in carb cleaner etc and get all the gunk out, should be better then...
If not, replacement time...
Threads: 71
@srowell - gti6
@ruan cheers bud sounds about as simple as I was hoping will whip that off in the morning and give it a clean
Threads: 115
26
Car Model/Spec: 306
Ive also had this happen a few times on my6 only ever happens when breaking to stop.
Threads: 289
92
Car Model/Spec: Phase 17 R26
If it doesn't solve the issue, although the OEM ones are expensive, there's no point buying cheap replacements as they are known to go fairly quickly anyway. It's better off paying the £80 for a Magnetti Marelli (sp?) one.
Threads: 169
91
I your cleaning the icv, use carb cleaner as said, but use a white spray grease or similar to lubricate it. WD40 will dry up in no time and you will be back to square one.
As Scott said, I found an old pattern part ICV and it lasted bugger all time. It's worth spending the money and buy it once, rather than replacing it in 6 months...
Threads: 71
(19-06-2012, 01:59 AM)R45_ODV Wrote: Ive also had this happen a few times on my6 only ever happens when breaking to stop. same here stop at a junction engine dies
(19-06-2012, 07:13 AM)Grant Wrote: I your cleaning the icv, use carb cleaner as said, but use a white spray grease or similar to lubricate it. WD40 will dry up in no time and you will be back to square one.
As Scott said, I found an old pattern part ICV and it lasted bugger all time. It's worth spending the money and buy it once, rather than replacing it in 6 months... got plenty of carb cleaner will give it a go later, and start saving for a new one as this isn't the first time this cars had issues with it, just first time in my ownership.
cheers for advice guys
Threads: 169
91
Fair play.
If you don't have any luck I have a magneti marelli one here. Not sure on function of it, but looks newish. £10 posted...
Threads: 71
cheers bud, sadly £10 is more than I can afford right now, if its still giving issues in a few weeks I should be able to afford that
Threads: 448
51
I now posess two. Both working ![Smile Smile](https://www.306oc.co.uk/forum/images/smilies/smile.png) giving the spare a bloody good clean up and a nice coating of lube. Keeping it for when the other dies lol
Threads: 169
91
(26-06-2012, 12:09 PM)kernow_joe Wrote: cheers bud, sadly £10 is more than I can afford right now, if its still giving issues in a few weeks I should be able to afford that
Paypal me the price of a 1st class stamp and you can have it. I have no use for it, just collecting dust
Threads: 71
mate you're a star but I literally don't have a penny to my name ![Sad Sad](https://www.306oc.co.uk/forum/images/smilies/sad.png) got the fuel in my car and all the food I spent the last of my money on in the week
Threads: 169
91
PM me your address pal, I'm sure you can return the favor some day
Threads: 71
what a legend!! thanks bud, pm me your paypal aswell and when I get paid I'll sort you out
Threads: 130
82
Car Model/Spec: 106 GO-NAD
you know he's gunna make you put your thumb in his butt, right?
not the 'thumb bum friend' for nothing...
