Threads: 1
Hi everybody, I'm in Lancashire England,
I am looking for advice, the ABS ring on a rear drum has destroyed it's self, all I need is a reluctor ring, Dealers want to sell me a new drum + bearing for around £180 they say the ring is not available on it's own????. (Drum and bearing are a complete unit) All I need is a ABS reluctor ring) The ring has an inside diameter of 69mm and 29 slots. I would not be adverse to fitting a secondhand drum (203 inside diameter) if anybody knows where to get one. Any help would be greatly recieved. Thanks
Threads: 9
19
Given 3 thank(s) in 1 post(s)
Welcome to the forums
I have 2 or 3 drum beams here if you want to come and get what you need then you are more than welcome, I'm 15 mins from junction 36 of the M6 and around all weekend.
Having said that I'm not sure any of them had ABS on...............
Threads: 1
Hi, thanks for the welcome and reply,
Can't get there this weekend could next, a quick check if it's abs, is the sensor lead goes through the back plate. Its the type that the drum and bearing are all one. Its driving me mad! I'm not tight but £180 to put a light out!!!!!
Threads: 9
19
removing the bulb is cheaper
there are 2 sizes of drum too just to make it more fun, looking from the wheel face of the drum do the top edges curve away from you or is it a fairly sharp corner? I know the one off my car doesn't there is no ABS cable on either of them but the other one I have with the smaller drums has holes in the back plates which have gromets in so I presume that the cable would have gone through there?! I will have to pull them apart and look won't I
Threads: 1
Hi, thanks again for your trouble,
The drum is relatively square, inside diameter is 203mm, the outer measurement is approx 230mm (9 inches), if the back plate has grommets in place the chances are there is no Abs fitted, the only chance is if someone has fitted an ABS drum, The drums are the same apart from the reluctor ring.
Thanks again.
Threads: 1
Hey, Just had a look at your photo stream
Great pics, used to do a bit myself when you had to develop the film??? (Showing age, not quite the box brownie though). Well done, look forward to seeing more.
Cheers
Threads: 9
19
Hopwood Wrote:Hi, thanks again for your trouble,
Thanks again.
I will have a proper look later on getting one from a local scrap yard will probably be your best bet I would think!
Hopwood Wrote:Hey, Just had a look at your photo stream
Cheers
Thanks film is good,
if your liking the phography there is a great thread on here with lots of contributions (turns out we have a fair few people who are into photography on here) which can be found here - <!-- l --><a class="postlink-local" href="http://www.306oc.co.uk/forum/viewtopic.php?f=5&t=203" onclick="window.open(this.href);return false;">viewtopic.php?f=5&t=203</a><!-- l -->
Threads: 214
Car Model/Spec: 306 hdi meridian
Given 1 thank(s) in 1 post(s)
Hello welcome to the peugeot 306 car forum.
Threads: 1
Hi,
I have systematically called all the scrap yards within a 25mile radius! At this rate the phone bill is going to cost more than the part, thanks for trying. Will have a look at the photo link later. Cheers
Threads: 1
Ha, Ha, Just been quoted £247 for a second hand drum by 247 spares!!!!!! I have found a firm in Lincoln that are making me a reluctor ring for £35 (xmol.com). It will be in the post tomorrow, so hopefully by weekend it will be sorted. Will let you know the outcome. Thanks for your help
Regards
Chris
Threads: 9
19
Grand, Its a bargain at that I feel I did look but then forgot to reply but none of the ones I have were ABS,
Threads: 32
3
Car Model/Spec: 94 XRDT now Gone, '99 Meridian
Welcome along for the ride fella
The Old_______and_______Slight Less Old
