Threads: 189
10
Car Model/Spec: E39 ACS 535i
Given 2 thank(s) in 2 post(s)
Getting a idea of what's needed to do the conversion.
Obvs gonna need to swap the tank and fule lines out.
The bay loom will be changed to a ph1 6 one, along with the dials. Lift up reverse cabel too
Will be using a unlocked ecu. So it should all be plug and play really, got a complete ph2 for parts if I do the conversion, so the odds and sods needed will be readdly avalible.
Just thinking is there anything I've overlooked.
Threads: 448
51
The engine?
Seriousness brakes, beam, suspension, loom, engine, gearbox, rack, ecu like you said odds and soda left then
Threads: 171
46
Given 1 thank(s) in 1 post(s)
Chris Wrote:got a complete ph2 for parts if I do the conversion, so the odds and sods needed will be readily Matt Wrote:The engine?
Riiiight....
Threads: 189
10
Its getting coilies, cambered beam, 21mm bars, 302mm brakes so that's all that stuff sorted.
Pas rack and arb will be swaped too.
Need a ph1 bay loom and dials for deffo though as the ph2 stuff won't work.
Threads: 448
51
They should be easy enough to sort out. Seen a few ph1 '6s breaking recently over ebay
Threads: 189
10
Yep indeed, colin at pug peformance should have some.
Threads: 448
51
Chris Wrote:Yep indeed, colin at pug peformance should have some.
That's who I get more of my parts from, he's only down the road, most of the time will deliver them too me
Threads: 374
38
Car Model/Spec: GTI 6
XU10?! Isn't that from jap cars.. Or am I thinking of something else??
Threads: 130
82
Car Model/Spec: 106 GO-NAD
deffo thinking of something else... XU10 is the 2 litre block
Threads: 374
38
samass Wrote:deffo thinking of something else... XU10 is the 2 litre block
Ill sober up and google what I'm thinking of! Should be a nice job Chris!
Also, while im here, Chris text me about Monday!
Threads: 169
91
Seems like a lot of work... Why not just buy a '6?
You already have the engine in then, without the increased insurance prices, hassle of changing logbook etc.
That way you can also sell me all those bits you listed for sale the other day, rather than keeping them...
Threads: 189
10
As for not buying a 6, it'll cost me money. A good ph3 is a grand upwards, which I dont have atm.
I've got the dt, and the parts needed to fix and convert it and I can make the money back from purchasing the car stripping the rest of it.
Only thing it'll cost me is my time.
This is all pending that the car runs when I collect it.
Threads: 169
91
Chris Wrote:Only thing it'll cost me is my time.
So your not going to declare it?
Increase in insurance and tax if you do...
Threads: 96
7
Car Model/Spec: 306 tractor
Tax would be the same, as both 2:0 litre and pre 2001
Insurance might be a killer though...
Threads: 189
10
Insurance will be declared for sure.
Wont be too bad I'm sure as a 6 is only like 100 more for the year over the dt.
Threads: 169
91
You'd be surprised mate. I dont know your stats (ncb, driving experience etc), but an engine change can add a hefty amount to the insurance. I'm with admiral, and for a like for like engine swap it would have been an extra £600, or to put a turbo on, an extra £210. Wtf?!?! Lol
That's with 3yr ncb and driving exp... Just so you can compare.
Threads: 130
82
what? a like for like engine swap added £600 to your premium??? so, if your engine died, and you put another one in exactly the same, theyd charge you 600 quid?? that seems a bit... cuntish...
Threads: 11
Yer swapping an engine always costs loads more to insure than a "proper one". I was looking at a 1.2 corsa with a 1.6 in and was cheaper by about 300 quid to just get a 1.6 corsa lol. Just make sure you get a good engine, a lot of them are showing there age now and suppose to do cambelt every 30k and very regular services. You could just get the Dt running nearly the same power with a crap load more torque for the same if not less effort. Shame to say it but my mate had one than left my 6 in a line, i was not ammused lol
Threads: 91
83
It's not as plug and play as you think...
You will have to play with the interior loom to get it to work.
And IMHO - the J4RS isn't all it's cracked up to be, from my experience.
(16-05-2016, 10:45 AM)Toms306 Wrote: Oh I don't care about the stripped threads lol, that's easily solved by hammering the bolt in. Nanstone GTD5 GT17S - XUD9TE
