Threads: 119
15
Car Model/Spec: Ph1 Diablo DT
Given 1 thank(s) in 1 post(s)
just though id show people the results i get when wet sanding. The wing it self was a home painted item by the previous owner who just painted it quickly rather than taking time to do it obviously a novice. today i was just doing bits on bobs on the car and so trialled a bit of wet sanding to see what could be done to the wing.
only pics iv got of the wing that make it obvious of how bad a match it was
So cracked on with the wet sanding the car had previously been clayed although this wouldnt matter as the sanding removes contaminants
Then cracked out my favoutite menzerna compound polish
The colour match is much better than before not 100% but much better and the orange peel has been reduced dramatically to an almost orange peel free finish.
Next up the whole Car!
www.prestige-auto-care.co.uk
Threads: 171
46
Wow nice job! Do mine next :-P
Threads: 169
91
Wicked! Much better paint match!
Did you use 1200,1500 or 2000 grit paper?
Where was the lacquer peel, or did you re-lacquer it?
Threads: 386
87
So basically you've just sanded it and polished it?
What happens when the polish wears off? Does it look 'sanded' again like in the second picture or am I missing something lol?
Threads: 119
15
Edited there wasnt any lacquer peel i ment orange peel. i didnt have any finer grade wet and try to hand i try to go for specific types of wet and dry paper this one was a very coarse 800 grit! The sensible way would be to start coarse and go finer often 1000, 2000 and 3000 this would have made the orange peel near on invisible. Only trouble with the wing being home painted you never know how thick the clear coat is with out the aid of paint detective tool but there a tad expensive! The menz compound i use is quite aggresive so can happily remove 800 grit sanding marks at a safe 2k rpm.
Threads: 119
15
Toms306 Wrote:So basically you've just sanded it and polished it?
polish doesnt wear off it should never be present on a finish where as wax should be. imagine polish as liquid sand paper the finer the polish the better the finish. so the polish here has removed 0.1000's mm of clearcoat to remove sanding marks and leave a flat finish.
Threads: 169
91
As above Tom, your ate getting wax and polish mixed up. Polish will 'wear down' the paint. The courser options being g3, tcut etc, working the way down the scale to things such as me guitars scratch remover or autoglym paintwork renovator etc.
You should apply a cut, finer cut (depends how mad you want to go but another finer cut), polish and wax(s)
To be fair, from the pictures it looks like you have done a decent job. Must have been hard removing the scratches from 800 grit paper! Lol. Nice job!
Threads: 117
21
Car Model/Spec: needs bwarrrp.
you can sort my bloody wheels out then
Threads: 581
195
Tom a polish (or compound like he's used) is basically a liquid sand paper but where as he's used 1000 grit paper, polish is usually so fine you could probably compare it to something like 7-10000 grip paper (if it existed!)
This is why you can't cut a car too often because eventually you will take the clear cost away completely and then it needs to go for a repspray
Threads: 119
15
Threads: 80
10
Nice results, i wet sanded some light scuffs out recently with 1500grit. Only had scratch x and my arm to polish it back up which was good fun...
![[Image: sigjpg.jpg]](http://i44.photobucket.com/albums/f32/cassandra--gemini/sigjpg.jpg)
Serious.
Threads: 117
21
top finnish that fella. still not sure why you took a pic of your front door though.
Threads: 130
82
Car Model/Spec: 106 GO-NAD
kingy Wrote:top finnish that fella. still not sure why you took a pic of your front door though. Exactly what I thought! Its like glass!
Threads: 117
21
wish i could get mine like that.
china seams to show up every little imperfections. well, it dose on mine anyway.
Threads: 119
15
Orange peel ruins a finish if it's real bad. Peugeot paint isn't to bad for it. The right compound polish finishing polish and wax plays crucial parts too. Doing things by hand won't get the same results as a rotary or da you just can't mimic there speeds by hand. If your local you can always come over
Threads: 117
21
Jenkosowls Wrote:Orange peel ruins a finish if it's real bad. Peugeot paint isn't to bad for it. The right compound polish finishing polish and wax plays crucial parts too. Doing things by hand won't get the same results as a rotary or da you just can't mimic there speeds by hand. If your local you can always come over my hand (and wrist) is faster than a bee's wing. :dance:
Threads: 119
15
Threads: 252
7
Car Model/Spec: Xud sedan/Xud estate
Given 2 thank(s) in 2 post(s)
We use Trizac 3000 grade discs which go on the polisher at work on door repairs its brilliant stuff
TD04 11mm Sedan, now 2.1 vnt
Provence Dturbo Dead
Blaze 1.6 Dead
Threads: 186
38
Car Model/Spec: MG ZR VVC
Given 21 thank(s) in 19 post(s)
How much to do an entire car?
Threads: 119
15
lolsteve Wrote:How much to do an entire car?
would be a tad expensive and be at the owners risk.... spent 3 days so far on this to keep the finish constant
Threads: 119
15
Threads: 117
119
That's pretty damn impressive...  hock:
Threads: 136
2
Car Model/Spec: Phase 2 Dturbo
Very good results! I've got some painting to do so ill have to try this after, hopefully ill have similar success!
Threads: 11
1
Car Model/Spec: Rallye
That is some seriously amazing results you have got there, majorly impressed man!!
I've been doing mine today to try and de-swirl and de-orange peel but it's hardly done sweet FA compared to how good yours looks there and that was using a DA with Sonus 3-stage polish and clayed before.
Definitely going to crack out the 2000 grade wet n dry though next time I do it as to be honest, I've never had the balls before but that is exactly how I wanted mine to look like!
