02-05-2012, 12:43 PM
Right all you need for this job is
Fuel filter
Gloves
Rag
Strength
These have to be the best gloves ive ever bought... £1 from Wilkinson they do not tear unlike "professional" glvoes which rip at the slightest bit of wind
Old rag to catch only fuel droplets
Turn 90degrees and it will pop off..be careful as some people have snapped the pipes
If you want to savoir all the fuel then leave it at an angle for a few mins (keep the gold ring safe)
Ensure you have a Peugeot Fuel Filter
Take the old one out - Only bout 10k between the fuel filter change so not that bad
Whilst its out its good to check there are no unwanted residue metallic bits in the system
Then simply ensure it all lines up once new filter is in (filter will fit in 1 way only) and pop top back on with even pressure all over and turn 90degrees back to start
Then crank it over and run for a few mins to ensure any air has escaped
Hope it helps
Fuel filter
Gloves
Rag
Strength
Hope it helps
