15-07-2020, 05:06 AM
I left my 205 with fitted Gti-6 engine in the garage for about 6 months and now it won't start. It used to be the best starting car I think I've ever owned!
Things I've done so far:
1)Fitted a perfectly charged battery which will start a 306 Diesel no problem
2)Checked the fuel line to the rail which spurted fuel when I released the jubilee clip (I dont know where the pump is to give it 12v)
3) checked the spark to a coil plug lead and there doesn't seem to be any flashing while cranking ..
4) checked the voltage on the spark coils which seems to be only 10.5 and drops to 4.5 when cranking
5) Checked the cranksensor on its pins 1 and 2 which showed a resistance in the Kohms not the 400 ohm specced.
6)Checked the cranksensor on its pins 1 and 2 while cranking which showed a voltage of about 0.8v not the specced 1 to 3 v
Have googled and googled but haven't found anyone with this issue.
Please help!
Cheers
james in NZ
Please help!
Cheers
james in NZ
