Threads: 5
Car Model/Spec: Pug 306 5d xsi aussie spec
Country:
I got a 2001 xsi 5 door . I want a little more power has a cat back exhaust .
What els would ppl recommend to up power a bit more . I am in Australia so some things are illegal like pod unless enclosed and I been told that u loose power cause of them also is there flash tubes or anything
81
Hi. I spent a few years and a lot of money putting bodies and a gti6 exhaust manifold on a 1.8. Its the same stud pattern. It only made about 10 hp more. ECU tuning isnt readily available and being N/A you wont see many gains. You can put gti6 inlet and exhaust on it but without being able to adjust the map to suit you wont see many gains.
The best thing you can probably do is keep the exhaust on. Maybe put a filter on for more noise but be careful for heatsoak. Spend your money on some other things like Bilstein B12 suspension and eibach springs. You can git a gti6 box which may help you feel like youre going faster due to the shorter gearing.
If you do get it tuned it would be a few hundred... at which point you might as well have just bought a gti6 engine and drop it in.
Threads: 5
Country:
My wife's cuzzen works for haltech so stand alone ECU ain't a issue
81
Ah I didnt see the Australia bit. Best whack a haltech on there and get it mapped up then. Then put a gti6 head and manifolds on. Maybe a turbo.
Threads: 5
Country:
turbo would be nice i am on look out for some gti6 parts but hard to find in aussie .
i am thinking of buying a whole xsi engine and rebuilding it not sure if i wanna go n./a or forced induction
