Threads: 25
1
Car Model/Spec: 1999 Rallye || 1999 HDi
Tried jump starting a pos golf with a mate yesterday
My mate tried starting it about 8 times before I went round and noticed that it had 'Immobiliser Active' on the dash so it was never going to start, at this point my car smelt hot and was smoking from what I assume is the crank pulley (big one at the bottom?)
I also noticed the idle had dropped from around 1000 to 800 this morning it idled at 800 and once I got to work about a 20 minute drive it was smoking again
How do I go about fixing this?
1999 - Black Rallye A/C
2002 - Silver 206 1.4 HDi LX
Threads: 145
5
if its a hdi 2l then 800 is the idle speed, but check.
smoke, aux drive belt overheating or even the crank pulley "rubber sandwich" getting hot, must be heat and quite a bit for smoke, unless belt slipping or something getting tight.
check aux drive belt as that failings can bunch up around pullies pressing in the plastic cam belt cover taking the cam belt out, destroyed engine, dont boost start with a pug 306 or any modern car, use a battery
Threads: 386
87
The aux belt tensioner is sprung loaded on the HDi, it can't just tighten itself.
I would say the smoke and smell probably came from the alternator given you were trying to jump start at the time.
Remove the aux belt and see if the smoke continues.
Threads: 25
1
09-11-2018, 08:48 AM
(This post was last modified: 09-11-2018, 08:48 AM by wainwrightj.)
To clear this up the A/C Pump has broken and doesn't spin freely
The pulley would jam up, the belt would rub creating the smoke
I've bought a shorter belt (Gates 6PK1173) which I'm going to use when I remove the broken pump
Threads: 386
87
Ah, makes sense! Don't leave it too long, if the aux belt snaps on these it often takes the cambelt out as well.
Threads: 145
5
Glad you found the problem before you get more......interestingly the citroen despatch with the dw10 engine has no a/con but uses an idler pulley where the a/con pump is, didnt have the time to remove that ( wanted the engine as well but hayho ) before the scrap man came, he came early the bugger.
Threads: 101
2
Car Model/Spec: 306HDi 90 LX
I thought it was possible to jump start modern cars. if done with care.
It goes, it stops (as reqd).
Hate Housework!
Threads: 145
5
Is it worth the risk i wonder.....
