Gearbox
Gearbox
Just need to find out if the 307 2.0 hdi gearbox is the same as a 306 hdi gearbox ny own one shit itself today
Sent from my SM-A520F using Tapatalk
Pretty certain there not as the 307 has a hydraulic clutch
As above, hydraulic clutch and cable shift so not the same.
engine sits at a different angle in a 307 also I believe.
the clutch mechanism is easy to get around.
307 also uses an ML box on the higher power 2.0 hdi's.
