air filter 306 gti6
Hi all, I'm new to the forum. Recently purchased a 6. Any recommendations on what air filter set up is best on these?
cheers!
The stock air filter is pretty good. Id suggest just cleaning up the oem air box. You can fit a cone filter but youll get heatsoak in the bay and it may get wet if you mount it low down!
Having done most things I would suggest the money would be better spent on making sure the brakes and suspension are set up. If you want to do anything to the engine/box a lightened fly wheel probably gives the most noticeable improvement. Fit it when you need a new clutch to save £££.
+1 on the stock air box tbh, they're getting harder to find too - be worth tidying it up before it turns to dust like most of the others!
  Inlet extension for air filter; GTi6 - what do you use? ginge191 15 9,011 08-07-2013, 02:35 PM
Last Post: Puggie
