Threads: 66
Car Model/Spec: 306 Estate - Ph1 Dturbo
Given 6 thank(s) in 6 post(s)
On the quest for arp headstuds for either dw10 or xud9. If any ine has a set ready with machined spacers to suit hdi spot on!
Cash waiting!
Still Living For The 306
306 Ph1 Dturbo Estate
205 1.9 GTI (Rust.In.Pieces)
306 HDI Stage 3 Estate (Rust.In.Pieces)
Can buy direct fit ones from ARP if you work it out
Threads: 66
(07-10-2017, 05:28 PM)Piggy Wrote: Can buy direct fit ones from ARP if you work it out Struggerling to work it out  got the originals worked out but dunno if they can work with those figures. Did contact them early last week
You don't need to contact them..... Just get ya head in some basic math and a straight rule. Plus a pad
Threads: 66
Do i need to add on aditional lentgh tho for the nuts?
And will i require the washers
Threads: 110
20
I could possibly also be interested in some if you find out any more info justin.
Threads: 127
33
Car Model/Spec: ZX Volcane TD
07-10-2017, 07:00 PM
(This post was last modified: 07-10-2017, 07:00 PM by zx_volcane.)
(07-10-2017, 05:59 PM)dr_jekyll Wrote: Do i need to add on aditional lentgh tho for the nuts?
(07-10-2017, 06:26 PM)Frosty Wrote: I could possibly also be interested in some if you find out any more info justin.
i'm going to be ordering some sets - can add you both in if you want
drop me a msg here or FB
Threads: 66
(07-10-2017, 07:00 PM)zx_volcane Wrote: (07-10-2017, 05:59 PM)dr_jekyll Wrote: Do i need to add on aditional lentgh tho for the nuts?
drop me a msg here or FB I would deffinatley be up for that!
Found a company under the following web address that provide kits for xud9 https://www.dp-engineering.nl
Ive contacted them frosty in hope they can provide us with a direct fitting kit for our dw10.
What ive managed to find out so far is the fitment of an xud9 is m12x1.5 148mm long vs dw10 thats m12x1.5 130.5mm long.
Unsure what the nominal lentgh of an xud arp is so atm ive emailed the company and asked them if they can supply an arp headstud 18mm shorter then the xud9 one they list.
Worst case scenario is we have to buy xud9 ones and machine spacers.
Threads: 127
33
(07-10-2017, 07:12 PM)dr_jekyll Wrote: (07-10-2017, 07:00 PM)zx_volcane Wrote: (07-10-2017, 05:59 PM)dr_jekyll Wrote: Do i need to add on aditional lentgh tho for the nuts?
well lemme know, i'll be sorting it early next week.
dp engineering used to do a set, can't remember if they used arp studs though or just custom studs with arp nuts - used to work out expensive with them after adding tax and delivery.
Threads: 110
20
Ok cheers tom, will let you know as soon as i know. Ideally be nice to have direct fit ones to save having to sort out and use spacers.
Threads: 66
07-10-2017, 07:18 PM
(This post was last modified: 07-10-2017, 07:19 PM by dr_jekyll.)
(07-10-2017, 07:15 PM)zx_volcane Wrote: (07-10-2017, 07:12 PM)dr_jekyll Wrote: (07-10-2017, 07:00 PM)zx_volcane Wrote: (07-10-2017, 05:59 PM)dr_jekyll Wrote: Do i need to add on aditional lentgh tho for the nuts?
dp engineering used to do a set, can't remember if they used arp studs though or just custom studs with arp nuts - used to work out expensive with them after adding tax and delivery. Im a deffinate yes and have money waiting.
As said if the company your using tom can supply the xud9 ones and some the same spec but 18mm shorter it would be even better for dw10 guys
Threads: 58
know one on this forum willing to hand out the part numbers?
Threads: 66
(08-10-2017, 03:43 PM)Stef205 Wrote: know one on this forum willing to hand out the part numbers? Apparently not
I can't remember them off hand..... But if people weren't lazy, had a ruler and a stock bolt.... It wouldn't take long to work it out. All the info you need is out there. Don't even need a stock bolt tbh...can find the lengths online.
Threads: 127
33
(08-10-2017, 07:21 PM)zx_volcane Wrote: 8008135
Threads: 66
Checked the codes out tom that we were given and they do check out.just one more thing left to double check fitment
Threads: 465
114
Car Model/Spec: Vauxhall
(08-10-2017, 09:47 PM)Piggy Wrote: (08-10-2017, 07:21 PM)zx_volcane Wrote: 8008135
code checks out OK for me!
| Y |
Threads: 66
(09-10-2017, 07:36 AM)cully Wrote: (08-10-2017, 09:47 PM)Piggy Wrote: (08-10-2017, 07:21 PM)zx_volcane Wrote: 8008135
| Y | Wasnt refering to that but did take me a while [emoji23]
