Piston Rings
Piston Rings
Just wondered if people bothered renewing piston rings on XUDs when changing the rods? Havnt really looked into the price of them yet, just getting a list together of what il need. Or instead of replacing, do the old ones need re-gapping or left well alone? Couldn't find many threads relating to general renewal, so im assuming its not really necessary to start with Smile
1st project- Red Peugeot 306 DTurbo 1998
2nd project- Silver BMW E38 1999- Sold
Daily- Black Mitsubishi L200 Series 5
https://www.spritmonitor.de/en/user/Hobo_Ash.html
(12-09-2017, 01:46 PM)Hobo Ash Wrote: Just wondered if people bothered renewing piston rings on XUDs when changing the rods? Havnt really looked into the price of them yet, just getting a list together of what il need. Or instead of replacing, do the old ones need re-gapping or left well alone? Couldn't find many threads relating to general renewal, so im assuming its not really necessary to start with Smile
A lot of people dont bother to be honest mate. Have a look at them and label each piston to the correct cylinder when removing, if the clyinder is lipped though youll probably find theyll need replacing and a light hone. All comes down to when you strip it in my experience. Obviously if youre gonna full hog with the build is it worth doing it be half??
Ok cool, il have a good look when i get round to taking it apart. Depending how much cash i have next year might determine if they get changed, think im going to need a few bags and labels to keep the pistons and valves in order! Im assuming if a ring goes, it wont damage anything else? If i get smoke and a loss of power i can compression test it before i cause any damage?
If a ring goes will more than likly score the bore that if youre lucky you may hone but 9 times out of ten they need machince work
oh ok, maybe I will replace them Smile will be nice to keep the maintenance costs down to a minimum once its finished!
quick edit- you heard much about Goetze piston rings? not got the money for them yet, but having a quick look they seem to be readily available Smile
If the engine is old / done alot of mines there will be lips on top of bore, and also rings will be weak. Hone and replace.
If the engine has been looked after/not huge lip (will alwats get some form of a lip, check its not mostly carbon), If engine is good condition I would reuse rings. As said take care when pushing rods/piston assembly out and always use ring compressor tight, and just light taps pushing pistons back in. The pistons should never be forced back in this breaks rings.
I have never replaced rings while rebuilding XUD's never seemed worth it when they are worthless anyway.
  Max Piston Protrusion / Notches Cford 2 2,410 03-08-2017, 05:52 AM
Last Post: Cford
  Piston Ring Modification JTaylor2005 10 3,878 08-09-2016, 01:59 PM
Last Post: zx_volcane
  Piston Wear 306Dan 3 1,741 10-08-2015, 07:44 PM
Last Post: craig306
