Threads: 110
20
Looks like you want to let the hand brakes cables back a reasonable bit and the spring on the bit thats goes to the stop adjuster wants to clip in from behind the shoes not infront from memory. Can't see what difference it makes but that's what I've always seen them like.
Threads: 42
28
looks fine apart from needing to back off the cables as mentioned, then take up the slack with the shoe adjuster.
you only want to remove the slack in the cables with their adjuster not use them to adjust the shoes.
