Threads: 214
Car Model/Spec: 306 hdi meridian
02-07-2017, 11:56 AM
(This post was last modified: 02-07-2017, 11:59 AM by Welshy_Pete.)
I've changed the discs, pads, calipers, hand brake cable managed to get everything working fine 306 hdi.
Now there a hissing sound coming from the brake pedal area. You can drive and it will start hissing but when you press the pedal a bit it goes then either comes back or goes random. The pedal goes a bit spungy I have noticed at the back of brake pedal very light fluid damp over the master cylinder seal.
So its all pointing towards a new brake master cylinder?
Threads: 371
29
Car Model/Spec: ford fiesta
Hissing will indicate the brake servo. Check the pipe leading to it for leaks. If not new servo time
Threads: 214
03-07-2017, 09:25 PM
(This post was last modified: 03-07-2017, 09:29 PM by Welshy_Pete.)
What problems does the one way Vacum valve solenoid cause?
Also how do you test this part?
Suck/blow through it and see if the one way valve does its job.
Threads: 26
Car Model/Spec: 306 HDI D Turbo
Welsh can i ask how long it took for you to do and some steps you took to do it as im having to do mine if i can find a break booster/servo
