Threads: 14
Given 6 thank(s) in 6 post(s)
it may just need adjusting but do the disk and pad first
Threads: 371
29
Car Model/Spec: ford fiesta
discs and pads. clean grease lubricate and adjust. I recently dont mine and the sliding pins were partially siezed as well.
Threads: 58
3
Car Model/Spec: Loads
Given 9 thank(s) in 9 post(s)
They are crap even at the best of times, as said new parts, clean the carriers up and it should be OK
Threads: 70
10
Car Model/Spec: HDi Estate
There is a guide here on how to adjust them PROPERLY, you must follow the procedure for this, 306 is a bit different to normal cars for adjusting.
Threads: 82
27
Be worth noting if it's still crap you may well need to replace the cables too
Threads: 465
114
Car Model/Spec: Vauxhall
peal the rubber boot back on the calliper hand brake arm and lube up the rusty pivit points, work the lube in and it should bring the handbrake back too life as it normally seizes in the pulled direction so the adjusters dont take up
Threads: 3
Car Model/Spec: 306 hdi
Country:
cheers guys.. it passed but only just.. its had new disks and pads.. the tester said i should replace the cables easy job or not??
Threads: 1
Car Model/Spec: Peugeot 306 1.6
Country:
Hi does anyone know how to remove the gearstick knob on a 306 automatic, I can't seem to find a way to do this
Thanks
