27-11-2016, 08:31 PM
![[Image: 7e4215a90e8e25cdc387ba147617e558.jpg]](http://uploads.tapatalk-cdn.com/20161127/7e4215a90e8e25cdc387ba147617e558.jpg)
![[Image: f325c1cba823e99dd304d250e572e08d.jpg]](http://uploads.tapatalk-cdn.com/20161127/f325c1cba823e99dd304d250e572e08d.jpg)
Removed this 1.9na out of my peugeot 309 and fitting 306 d turbo lump.
Will I be able to use the 309 thermostat setup and fuel filter on the d turbo engine?
Sent from my SM-G925F using Tapatalk
D turbo conversion advice wanted
![]() ![]() Removed this 1.9na out of my peugeot 309 and fitting 306 d turbo lump. Will I be able to use the 309 thermostat setup and fuel filter on the d turbo engine? Sent from my SM-G925F using Tapatalk
27-11-2016, 09:28 PM
not sure, Mark Fish will know, as will Sam Barker amongst others, why do you want to? . .
27-11-2016, 09:30 PM
27-11-2016, 09:35 PM
27-11-2016, 09:36 PM
I get that...but you have to remove those items for the swap...so may aswell just take it across to the other engine and see if it fits. Iirc the fuel system is different. Stat opening is different too iirc
28-11-2016, 12:15 AM
Not a 309 but on my bx I swapped from a 1.9 nad to a 1.9 turbo diesel and just transferred the whole cooling system across, thermostat opens at 83c on my nad same as the turbo diesel so swapped that across also.
28-11-2016, 06:17 AM
As piggy and chris say, What I did with my engine conversion even though its a different car, was just use the cars fuel and coolant system.
28-11-2016, 07:03 AM
(28-11-2016, 12:15 AM)Chris_90 Wrote: Not a 309 but on my bx I swapped from a 1.9 nad to a 1.9 turbo diesel and just transferred the whole cooling system across, thermostat opens at 83c on my nad same as the turbo diesel so swapped that across also.I'll try transfer everything across then it does look very similar Sent from my SM-G925F using Tapatalk
28-11-2016, 07:21 AM
I'll say yes ; most XUD models, NA/t models have very similar stat setups : unsure why you would swap it over though ...
28-11-2016, 07:24 AM
(28-11-2016, 07:21 AM)ginge191 Wrote: I'll say yes ; most XUD models, NA/t models have very similar stat setups : unsure why you would swap it over though ...I havnt got all the d turbo cooling setup but I have the na so trying to use as much of the na stuff as possible as it's there. Sent from my SM-G925F using Tapatalk |
Turbo Advice | The Phil Billy | 7 | 2,585 |
07-11-2016, 08:48 PM Last Post: The Phil Billy |
Turbo change advice on xud | ashdturb | 2 | 1,434 |
19-11-2015, 06:25 PM Last Post: ashdturb |
facelift berlingo d turbo conversion | Jamieh2013 | 3 | 2,108 |
20-03-2015, 11:41 PM Last Post: xudlingo |
