11-04-2012, 08:56 PM
I'm in the process of upgrading my shocking stock sound system, I've just got a pair of coax jbls in the front, these will be moved to the rear when I get some components next month, I want to amp this lot up with a 4 channel amp. I'm not keen on cutting into to loom so was going to run the speaker cable from the amp to the wiring adaptor my stereo uses and splice into that, my concern is the length is going to be a problem especially for the rears. Is there a safe length to keep within for the best results? Is there any other options without cutting the car loom? Is my plan going to be ok? I'm not going for extreme just want the best from my equipment. :fooby:
PH1 FTMFW!
