Threads: 3
Car Model/Spec: 306
Country:
05-07-2016, 04:23 PM
(This post was last modified: 05-07-2016, 04:31 PM by roger352.
Edit Reason: Forgot name
Hi
I have a t reg 306 auto which will not start. The starter clicks but that's it. Could it be the not start in gear switch forgot what it's called.
Any ideas? Thanks for your help
Inhibitor switch
Threads: 18
10
Car Model/Spec: 3 x 205 GTi & 306 HDi
Inhibitor switch I think is what you mean.
If the starter does click then I'm guessing that the switch is working to some degree as otherwise you'd logically get nothing at all to the starter solenoid.
Easy way to prove it is to see if you get something different (i.e. nothing at all) if you try starting the engine with it in something other than park/neutral.
Threads: 3
Car Model/Spec: 306
Country:
05-07-2016, 04:36 PM
(This post was last modified: 05-07-2016, 04:39 PM by roger352.)
Tried that still get the same thing in all gears. Just tried it again n&p starter clicks rest of gear nothing
Threads: 8
Car Model/Spec: 1996 306 saloon
Try rocking the car in neutral..
If it was the switch there would be no crank and no noise...
Sounds more like a dead starter/bad conection
