Threads: 476
81
Car Model/Spec: 306 Rallye
Hi Guys,
I was about to buy a pump for my air bed... but i always carry a tyre inflator around. Does anyone know of an adapter i can use to pump up an air bed with it? I need a male tyre valve to male air bed size bit.
Sam
Threads: 61
4
Given 6 thank(s) in 5 post(s)
I forgot my pump last time and took off the turbo pipe off my xud and pumped it up that way worked well 😀
Sent from my E6653 using Tapatalk
Threads: 47
14
Car Model/Spec: Ford cougar v6. Mk6 Transit
Given 20 thank(s) in 20 post(s)
(04-07-2016, 05:48 PM)aggyj17 Wrote: I forgot my pump last time and took off the turbo pipe off my xud and pumped it up that way worked well ?
Repped!
I Don't Have A 306.
Threads: 476
81
unfortunately i dont have a turbo :/
looks like you can do it with just the exhaust...
https://www.youtube.com/watch?v=igOxPwqPXr0
Threads: 47
14
Thinking about it in a less comedy way. Would it not just kill you with exhaust gasses as it inevitably leaks out all night?
I Don't Have A 306.
Threads: 591
54
Can pick up my airbag pump (plugs inthe car) if you want on way past?
Threads: 476
81
(04-07-2016, 07:04 PM)Piggy Wrote: Can pick up my airbag pump (plugs inthe car) if you want on way past?
i can buy one for £10. just after any neat tools or ideas to save me £10 and hassle of packing anything etcare you not coming?
Threads: 0
Car Model/Spec: Protest R26 Liquid yellow
Country:
(04-07-2016, 05:45 PM)Eeyore Wrote: Hi Guys,
Sam
I got a footpump and leccy pump if you can wait, wiull be bringing both to Pugfest
Threads: 162
21
Given 23 thank(s) in 23 post(s)
I used to use an electric tire pump until I over inflated my air bed and popped it. I used an old tire valved pushed in to the inlet.
It takes too long and is noisy.
Get a proper inflator, it's a lot faster.
Threads: 581
195
Ive got a 12v airbed pump you can use but only if i can share said bed with you....
Threads: 591
54
(04-07-2016, 07:22 PM)Eeyore Wrote: (04-07-2016, 07:04 PM)Piggy Wrote: Can pick up my airbag pump (plugs inthe car) if you want on way past?
Yes...but on sunday
I live like 15miles away!
Comfy bed for the win
Threads: 476
81
if i have to share a bed with niall in order to use his... it might be worth a trip to yours piggy.
Threads: 581
195
(04-07-2016, 08:24 PM)Eeyore Wrote: if i have to share a bed with niall in order to use his... it might be worth a trip to yours piggy.
Theres 2 ways this is going to go Sam and only one of them in consensual. Your choice.
Threads: 48
5
Car Model/Spec: Peugeot 306 S16 Cossack
Given 2 thank(s) in 2 post(s)
I'll bring an electric air bed pump
Peugeot 206 GTI HDI
Volvo V50 2.0d
Volvo XC90 D5
Threads: 541
124
You can get an adapter, I have one for my tyre pump but as I'll have my air bed pump with me would you like to borrow that?
Threads: 143
10
Car Model/Spec: Ph3 XUD
Given 8 thank(s) in 8 post(s)
I may flutter my eyelashes at one of you on Saturday as I only have a footpump
Also, imagine using your exhaust to do it when you have an XUD
Threads: 476
81
looks like there are going to be loads there. Ill borrow one on the day. cheers lads.
Threads: 42
28
tyre inflator pumps will get pretty hot trying to do an airbed as you need lots of frre air volume not pressure.
hence why turbochargers work quite well.
Threads: 202
58
Don't you have a 3d printer anyway Sam?
Threads: 476
81
(06-07-2016, 12:21 PM)Jonny81191 Wrote: Don't you have a 3d printer anyway Sam?
nope havent got my own. i use shapeways.
Threads: 91
83
Turbocharger FTW.
I remember doing mine with the GT2052V at FCS '11 I think... Never seen a bed inflate that fast!
(16-05-2016, 10:45 AM)Toms306 Wrote: Oh I don't care about the stripped threads lol, that's easily solved by hammering the bolt in. Nanstone GTD5 GT17S - XUD9TE
Threads: 465
114
Car Model/Spec: Vauxhall
